Zebralight H31
thaugen
USA
According to Zebralight the H31 will work with an AW RCR123a with shorter runtimes...but just how much shorter compared to a CR123a?
Look what I just found from another post from Coors...
In case anyone interested may have missed this, I'll post my H31w/AW-R123a runtimes, again, at the top of this page :)
H1- 49m 57s
H2- 1h 20m 59s
M1- 7h 28m 43s
M2- 11h 18m 53s
L1- 2d 20h 3m 7s
L2- 8d 5h 28m 57s
It is ok, and the H30 & SC30 were designed to run on rechargeables. I have the SC30, and only run RCR123's in it. The light is close to 2 years old, and still works great.
I can confirm the H31 works on RCR123s as I had a protected Ultrafire 880mAH 3.6v cell and once it was time to recharge I had it stuck in the body and needed to glue a pencap to pull it out. So be careful with thicker protected cells in the H31. I do run the Tenergy LiFEPO4 3.0v RCRs and they are the same exact size as CR123 primaries and also only 3.0v. They run a long time and I can't be more specific as I use low and low 2 the most so my cells last me for months using the light at night mostly for short <5-30 minute periods at a time, pretty regularly every week.
i've never had problems using 16340's in my h31..I use protected trustfire flames and they fit perfectly..they are commonly accepted as larger than normal from what i've read..haven't measured runtimes, but I have never been disappointed with it running out of juice prematurely..for the lumens it produces it seems to be very efficient on 16340's..
