Anyone else have intermittent problems with their photon freedom after changing batteries?
Yorkshire Pudding said:Hey up! (Friendly Yorkshire greeting.) I've lurked on CPF for about a year. It's now time for me to come out as it were.
Right, that's the pre-amble out of the way. Down to business.
I too have a Photon Freedom with the same problem. The lower cell would be OK but the upper one would be discharged. The problem was caused by the green insulating material crumbling from the gold contact strap. This allowed the +ve of the lower cell to make electrical contact with the gold contact strap, thereby short circuiting the upper cell. I solved the problem by cutting two small pieces of plastic from a drinking straw and wedging them between the +ve of the cells and the contact strap in place of the green insulating material. Bit fiddly but it does the trick. Hope this helps, John L.
carrot said:I have opened up and taken out the batteries on my Photon Freedom a number of times -- three or four. Never had that problem. Maybe it's in how you're taking out/putting in the batteries?
bhds said:Do you get the flicker when dropping the first(bottom) battery in?
