But... but... the physics behind optics dictates that if you want a tighter beam that throws farther with no black spots inbetween the edges of brightess, the optic will need to be longer and bigger in diameter.
That's kinda why all the lights that are good throwers that use optics have relatively large heads. I mean, I know what you want, but it's just not quite possible. If it were as easy as just typing words on an internet forum, Surefire would have no R&D department!
Personally, I'd like a light the size of the Inova X1 with HAIII coating that has 5 levels of output ranging from 1 to 80 lumens and has a reflector that self-adjusts from uberthrow on the highest setting to all flood on the lowest two settings and a nice balance of throw and flood for the two remaining settings. Best of all, it wouldn't even have a switch, it would just know which level I wanted from reading my thoughts. It would run for 20 years from a new and completely safe hydrogen power supply and I'd like my choice of Sarah McLachlan, Winona Ryder, Rachael Weisz Carla Gugino or Amelia Warner to bring it to me whenever I think about it and then stick around for a while afterwords.
Just because you 'want' something doesn't mean it's possible. Small reflectors are generally going to be floody, larger reflectors tent to generally be throwy. It's just physics, dude.
