teststrips
My Dad was going through his attic and found some lights from the past that he thought would be interesting to mod.
The first light looks an awful lot like a lighter. The top is plastic with door that you flip open to activate the light. It runs off of 2 AA batteries that are housed in the bottom (blue) part. The light also sports the boy scout logo.
The second light (small hard to see) is a keychain light made out of what appears to be a gold or gold coated metal casing. The bulb (burnt out) is almost exacly the size of a 5mm led, and was powered by a 625 mercury battery (common in older cameras) http://www.batterymart.com/battery/BAT-A625PX.html I will probably be buying some cr1232 batteries to power a 5mm led in this small case.
Light #3 is a lantern sporting a place for 2 C cell batteries in its base. It has a switch that makes contact to one of two bulbs. I am guessing they are for high/low, but both bulbs were missing, and dad doesn't remember.
Light #4 is a minimag for size reference. It sports a kroll switch and Auralight's hotwire mod
Light #5 is a small single cell AA sized light with a slide switch. I've already modded this one with a dorcy AAA logic board with a snow white LED from peak in it. I had to encapsulate the entire board into epoxy in order to mount it. There was a 2-3 mm gap around the LED when fitting the stock reflector (which I wanted to keep) so I filled that space with glow powder mixed into epoxy.
#5 was the one my dad seemed most interested it. "it was my dad's first flashlight" he said, making this my grampa's light - which would have some history to it. I plan on giving the new improved version back to dad so he has a piece of his dad that he can carry with him.
All in all, i believe these lights will provide me with hours of modding fun... as soon as I figure out what to do with them.
