LowBat
Although there is a flashlight that converts to a lantern by extending the bezel and exposing the LED, I'm wondering about how hard it would be to make an accessory that would attach to a flashlight's bezel and redirect the beam 360 degrees. I'm envisioning two parts; a stand to prop up the flashlight to a stable vertical position, and a cylindrically shaped diffuser that attaches to a flashlight head via a rubber grommet. Similar to the River Rock 4AA lantern, the cylindrical diffuser would have a polished dome at its end to redirect the beam outwards.
If a flashlight like the SL 4AA Lux was used the runtime and output should be sufficient for camping or home use. The advantage over a regular lantern would be very low cost and such a setup would be great for backpackers concerned with space and weight.
I could check my local TAP Plastics store for parts and see what I can come up with. Anyone have any idea of what's out there that might work?
EDIT: I'm wondering if this even needs a diffuser as the LED is recessed down in the reflector. I guess it depends on the amount of glare coming off the reflective dome.
