CroMAGnet
I just fired up this West Mountain Radio CBA II and it seems to work fine. I can see I will need to figure out a few things.
Can I get a few pointers to same some time and money? I'll be posting the graphs as I do them.
What I've noticed so far is that I need to aligator clip the sidewall of the flashlight and maybe use an aligator clipped to a small magnet that is sitting on the negative battery terminal. I'm also guesing that a magnet at the postive end will help keep a good contact with the head and even magnets in between eac battery to help give them a consistant contact. Any tips here?
Also noticed the new software doesn't have a pull down in the menu for the Lithium Primary batteries like the L91 so do I just use Alkaline from the pulldown? And how do I change the graph title?
Also what are the basic settings you guys recommend when using the basic Alks, L91's, NiMH's and LiON batteries. (Mostly curious about the Test Amps window and the Test Cutoff V)
I was using an L91 in a Ghost II and had the Test Amps at 0.20 and the cutoff V at 0.2 although I don't even know what "Test Amps" are.
Thanks for reading
Thanks for reading
