Help with microscope LED upgrade?
FirstDsent
Columbia, South Carolina
I have a small 20X field microscope. The stage lamp uses a small screw-based 5 watt incan bub in in a large (~.500") brass adapter that snugs into a pinch holder. The lamp runs off a single cr123. Can anyone suggest a self-contained Luxeon LED module that includes an appropriate resistor or regulator and a floody reflector? I imagine something like a surefire lamp assembly, but LED. I can adapt the holder to just about anything as long as the module isn't huge. I only have so much room to work inside the cover.
Thanks for any help!
Bernie
randyo
Hayward (Bay Area) CA, USA
Something like this?
Tektite LS-233
I replace the bulb in my Bausch & Lomb 10X Coddington Magnifier. It's not significantly brighter, but there is some improvment in intensity. However, the more natural color and longer battery runtime make it worthy.
FirstDsent
Tektite LS-233
Dude! That is almost perfect! My setup has a shallow polished stainless reflector that would benefit from the side-emitter.
I'm still open to any setups that include an integral reflector, but I can sure make this work. The brightness isn't so much my issue, as is battery life in the field, and diffusion.
Thank you,
Bernie
