hey, not sure if anyone has thought of this....but i am tired of the lil toy led arrays used as "aftermarket" lighting on motorcycles, most of the time they arent even as bright.
so matter taken into my own hands... i have 4 turn signals, right rear, left rear, front right and front left. i also have one brake light. each turn signal is about 2"dia and the break light is bout 4"x6". in the rear turn signals i want 2 ambers, and 2 red each...i dont think the stars will fit. how hard is it to do the smd soldering and doing the heat sink. i've only done through hole. i think for the front turn signals, i will just run 2 ambers each. and the tail light will be either 4 or 6 stars(they should fit).
i need help with how i can get the 2 lvls of dimmness that are needed. i was thinking bout getting a few buck puck or what not, and just under powering the lux's with them, then have a second on the brake or turn circut that will give the full juice. also sould i run reg lux's lux III's or the new k2's?
if i did the k2's then i would only need one per turn on each and 4 tail lights right..... thanx guys
btw i have an inova t3 as my emergency light with me at all times on my bike, love it.....
