MillerMods
3/4 watt to 1.5 watt Luxeon ARC using 1.2-1.5 volt NIMH/Lithium AAA & 2-level option
The drive current to the lux will be around ~250mA for 3/4 watt, ~350mA for 1 watt, and ~470mA for the 1.5 watt @ 3.2Vf. The pricing is as follows:
I supply ARC head $10
I supply ARC $35
1-stage add $25 or 2-stage add $35
Polished reflector $3
Parabolic reflector cut $10
TXOH $12
RV1H $6
A tiny light that's brighter than it should be... Priceless.
Clones are $28 for 1 stage and $38 for 2-stage. They are only available in 3/4 watt configuration. Add $6 for RV1H or add $12 for TXOH otherwise it's a random lottery pick for the Lux.
Note about clones: If you are not familiar with the quality of the clone, it's my suggestion that you buy one from a reseller here so you understand that they are not the best fit and finish. On the plus side though, I do hand select the best ones and discard the really bad ones so that my customers aren't stuck with a terrible quality expensive light.
I supply ARC $35
TXOH $12
RV1H $6
