I have a Universal Smart Charger that is supposed to handle 12v-16.8V for battery packs. I have been trying to use it to charge 12 batteries in FM's 12aa-3d adapter in one of his bored 3D bodies.
At first it seems ok, but, basically it is not charging the 12 batteries in the holder. When I use my DMM, I get some readings both on the holder and on the leads from the charger. However, at the end of it all it is not charging the batteries beyond 1.2V each, with not all that much mah's.
Have been using a Maha 4-cell charger to charge the cells and put them in the holder.
Has anyone else had issues with this charger? Do you have some suggestions for what I should try before I contact the vendor and send it back? Should I consider another option such as a Triton+12V power supply?
Thanks!!
Thanks!!
