cryhavok
I have for sale a ViReN original Q-III Heat sink for the Nuwai Q-III. This heat sink is completely new and unused. I was going to upgrade my Q-III with a U-bin LED but instead got some McLux creations:rock: so I won't be needing it and don't want it to go to waste!
This heat sink is 1mm shorter than the stock, so it can accommodate a FluPIC or other driver board. However, it is also perfectly suitable for using the stock driver. I asked if the shorter length would mess with the LED's positioning in the reflector and this is what ViReN responded:
"There wont be much difference as if you notice, the QIII has a spring loaded -ve contact, this contact will keep the heat sink up. this will be lighter as compared with the normal one.
LED will be placed as a normal position and wont have any negative effect as such."
Read about the heat sink here:
https://www.candlepowerforums.com/threads/87538
and here is the specific post:
https://www.candlepowerforums.com/posts/1286846&postcount=71
(mine is #3)
This cost me $10 originally, so I will let it go for $10 shipped CONUS. Thanks for looking!
*SOLD*
(mine is #3)
*SOLD*
