A little challenge for all you electronic whiz kids. Everybody is into the light "intensity" business. I'm looking for duration as well. Would the following be possible: Power source: 3 AA or the typical Petzl 4.5V block battery. Light source: a single 1W LS. Requirements: Design a circuit that uses a minimum of 280mA (at that current the light intensity is more than sufficient) BUT the light is to last at least 10 hours! Is it possible or how close can you get? I've used a simple voltage regulated circuit powered by 3 Sanyo 1700mAH to obtain 5 1/2 hours. Do that and I can possibly generate a nice market for the seller!
