Originally posted by Rothrandir:
i would like to convert my sacriligious mini-mag, but can't afford a dc/dc boost. what batterys should i use to power a luxeon at or slightly about specs. any other useful/helpful information would be appreciated. i have only modded 3d's thus far.
<font size="2" face="Verdana, Arial">Try modding that mini-mag with a luxeon from Inretech, and power it with 3 x 2/3 AA NimH. (easily available from several sources). The 3 cells are shorter than the 2-regular AAs, so you will just need a small spacer..-which you can make very neatly out of tightly formed Aluminum foil.
Activate the flashlight for 5-10min.
If the head becomes very warm, you may have to resistor it. It probably won't, because I suspect most of the Inretech Luxeons have a relatively high forward voltage, and the smallness of those 2/3AA cells will help limited the available current also. You can, of course easily check it out with a DMM-shooting for under 500mA.
Also, if you happen to get a bit of a greenish tinted one, the higher voltage will "wash out" a lot of that unwanted tint.
-That's how I would do it on the cheap.
