Illum
I recently bought another nite-ize 2AA 3LED module and installed it in the minimag....the color was teal and the output was less than half, weak output.
I hooked up to the variable power supply running my previous module in parallel...at 3V my other module was at full brightness while the new module was a weak teal color:candle:, I adjusted the powersupply to 1.5V [~1.8 on my voltmeter], my old module ran white at half intensity while the new module emitted only a slight teal from the embedded die.
I know for sure i will burn out the module if i clocked the Vin at 4.5V [I burned out one module already under a few seconds, i oughta know], but i thought "well, see what happens since its unuseable anyway," well, it lit at the same brightness and comparable output to my old module.:naughty:
so my question is....is there a possibility the module may have been installed with an incorrect resistor value...say alittle high?
