MacTech
I've had my Fenix E0 (the Lighthound one) for 4 days now, i know 4 days is not enough time to draw any valid conclusions, but i'd like to post my experiences
I made the decision when i took it out of the packaging that i would *NOT* be babying this one, no, this one's going straight on the keyring to bang around with car keys and my Victorinox MiniChamp Lite
it's been banging around on the keyring for 4 days now, and the type 3 natural Ano is still flawless, no damage whatsoever
the beam pattern has a slight blue hotspot with a yellow corona, tapering off to a faintly yellowish spill, with dark-adapted eyes, the 5.5 lumens is more than enough for navigating inside the house, or for close up illumination of keyholes, which are it's intended purposes
there have been no accidental activations when carried in pocket, unlike my Fenix E1 which has turned itself on numerous times in pocket or on the keyring, the on-off twist has just enough resistance to prevent accidental activation, the E1 has a much smoother, easier turning twist, so conversely i have to back the head of the E1 off more than the E0
for general use with non-dark adapted eyes, the E0 is often overwhelmed by ambient light, such as a room lit by a 20" television set, or in a bathroom with a standard 4 watt incandescent nightlight bulb, the E1 is clearly brighter in these situations, but that brightness comes at the cost of runtime
compared against my red Photon Freedom, the light intensity is roughly the same, the Photon has an initial brightness advantage but fades quickly as the batteries drain, the E0 holds it's brightness level for a much longer time, and obviously wins out for color rendition
as long as you keep in mind the purpose of the E0, an inexpensive, long runtime "emergency" light that uses a common, easily available battery, you won't be dissapointed, you want more brightness, go with an E1, want *lots* of brightness, go with an L0P, you want the gold standard of fit-and-finish, go with an Arc AAA P, bear in mind though, as brightness increases, runtime decreases, the E0 is *NOT* meant to compete with the likes of the L0P, or any Luxeon pocket light for that matter, it's clearly aiming for the Arc AAA P, that said, the Arc *IS* superior in fit-and-finish, but it's also more expensive than the E0, it's like comparing a Dodge Neon to a Mercedes Smart Car, both vehicles are small cars, but the fit-and-finish on the Smart is much better than the Dodge Neon
I'm very happy with my E0, but to be perfectly honest, they wouldn't make the best gifts for the Unenlightened, as they would judge the light based on it's brightness (or lack thereof), *not* the HA and excellent regulated runtime, the E1 or L0P would make a better gift to the Unenlightened
all in all, i'm happy with the E0, the HA is holding up well so far, the light produced is usable when dark-adapted, or for keyhole spotting, there have been no accidental activations (the E1 has run down 2 lithiums with accidental activations, i now only feed the E1 NIMH's for that reason), and the runtime is amazing, it's a great, long running keyring light
