MrAl said:Hello there,
If you are using a Luxeon Star (white) you can get away with using only
a single resistor to drive that LED from the USB port, of value 4.7 ohms,
rated at 1 watt (can also use two 10 ohm 1/2 watt resistors in parallel).
The difference in current draw is about 60ma more for the resistor than
for a down converter with efficiency about 80 percent.
This way you can save the converter for something else that really
needs it.
+ or - contacts. This doesnt matter.Illum_the_nation said:um...resistors are to be soldered on to the (+) contacts right? or it doesnt matter.
