HarveyRich
- Joined
- Oct 5, 2006
- Messages
- 434
This is my first post on the board, but I've been browsing for about a month now. I've recently purchased both the 3 watt LED 2 AA mini maglite and the 3 watt LED 3AA mini maglite. I agree with posters in other threads that the 3 battery lite is definitely brighter than the 2 cell one although I don't have a light meter and can't quantify the difference.
I believe I have some information to share that would be useful to Board members. I did some systematic run time calculations (although the brightness factor is clearly subjective since I have no light meter). No one, to my knowledge, has posted about the mini maglite runtimes with NiMH rechargeable batteries. Both worked just fine with NiMH cells. I tested both lights with 2000 mAH batteries (Lenmar) and then with 2650 mAH ones (Duracell).
The 2 AA cell mini mag appears to be regulated to put out a fairly stable light over time, as has been pointed out previously, and runs at a relatively constant brightness for quite a while. After a few hours it dims somewhat until it completely goes out without a "moonbeam," as has also been pointed out. For two runs at full charge using the 2000 mAH batteries I was able to run the light for 4 1/2 hours and 4 hr 45 mins, respectively For the 3 AA light I was able to get about 7 hours of light. However, around 2 1/2 hrs into the run time test, the light became less and less bright relative to the 2 AA mini mag. Thus, after 2 1/2 hrs, the 2 cell light was brighter than the 3 cell light until the 2 cell version went completely dark at about 4 1/2 hours. The 3 cell mini maglight became dimmer and dimmer until there was little useful light by 6 1/2 hours.
I repeated the same tests on both lights using the 2650 mAH Duracells. The 2 battery mini maglite went a full 5 hr and 50 minutes before it died. The light during that time was still reasonably bright and could be used outdoors and indoors easily. Thus, the useful light period (not a formal definition of run time to 50% brightness) before dying for this light was nearly 6 hours. The 3 battery mini maglite was still running and putting out dim, but usable light after 9 1/2 hours of operation. I was actually able to read newsprint easily in a darkened room at 9 1/2 hours on these batteries. The subjective crossover time when the brightness from the 3 cell mini maglite was about the same as the output for the 2 cell version was over 4 hours. Thus, for the first four hours, the amount of light emitted from the 3 cell lite was equal or greater than that from the 2 cell mini mag.
In summary, although I don't have a lot of LED light experience, I found the combination of run time and excellent 3 watt output from both of these lights to be just excellent. I'm very glad I own one of each and intend to operate them using the 2650 mAH Duracells
