<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by FlashlightDude:
PS to Stingmon,
What is your favorite small carry and larger carry leds????
<HR></BLOCKQUOTE>
Hard to say... there are so many good ones available.
I've taken a liking to the Princeton Tec Attitude as a smaller (pocket sized) model as of late. And the Arc-LS with 2-AA body is never more than an arm's reach away. Can't wait until the production model makes its debut.
For a big light, you really can't go wrong with an Expedition 300. Some say the Lightwave 3000 is better, but I have yet to see one so I have no basis with which to make a comparison.
The Turtlelite II is a good choice for a medium sized light to throw in the tacklebox; it's waterproof, it floats, and is reasonably bright. The marine Eternalight would also work here (waterproof, also floats), but it might be more likely to "go off" inside the box because the switch is not recessed. A screwdriver handle or a heavy lure bumping into it would do the deed.
For the keychain, you can pretty much choose between the Photon and the Arc-AAA.
The Photon is brighter for very brief, intermittent usage, but the Arc stays brighter for longer; and it's cheaper & easier to change the battery than the Photon.
If you want something especially colorful and flashy, the Eternalight Rave'n is the only way to go. With all four LEDs going, it also functions reasonably well as a "white" flashlight, though the beam isn't as consistent as a real white LED's.
For incandescents, it would be a fair game between the Legend LX and the Surefire E2.
The Legend is brigher, but it's also larger.
But the Surefire is smaller and more solidly constructed, even if it isn't as bright.
The Legend is good for those with shallower pockets, while the E2 is a more high-end product, and its construction shows it.
For even more economy, you probably can't go too wrong with a 2-AA Mini Mag. They're reasonably durable, and much cheaper to feed than any of the lithium 123 lights. But it isn't the brightest bulb in the pack, so to speak.
