luxeon k2 torch
axbol
hi chaps.
first post on here so please bare with me.
i have just ordered a luxeon k2 torch off ebay.
it states that it can use cr123 3 volts of 3.7 volts. is this right?
i dont want to put in 3.7 volt batteries and blow the led.
im pretty new to flash light stuff so if this is a thicko post, sorry
regards axbol......
oh by the way the torch uses two batteries, so to me there is a fair
difference from 6 volts (2X3volt) to 7.4 volts (2X3.7)
Long John
Spain, near Cadiz
Hello axbol and welcome to CPF:)
All depends on the light, so please give us more informations. Which light are you talking about:confused:
Best regards
____
Tom
axbol
hi longjohn , thanx for the wellcome.
the torch is---Ultrafire K2 LUXEON LED Torch
i have got rechargeable 3.7 volt batteries, just unsure whether to use them
regards axbol
Long John
Spain, near Cadiz
regards axbol
axbol, I have no experiences with this light. I did a search and found this description:
Made by High Quality CNC aluminum with Mil-Spec HAIII finish
Luxeon K2 Bulb for powerful output
100% Brand New
Durable aluminum reflector
On/Off button at bottom cap
Size: Length 13cm, Diameter 3.5cm
Use 2 x 3.0v/3.7v CR123A batteries (not included)
Holster and Handstrap included
Optional item: (Combine Shipment Only)
+GBP0.50 for 2 x Single use 3.0v CR123A batteries
+GBP8.25 for 2 x Rechargeable 3.7v CR123A Batteries + 1 Charger (for Home or Car use, World voltage, UK Plug installed)
So accordingly, you can use 2x RCR123 cells.
Best regards
____
Tom
