Josey
Withdrawn. Thank you for looking
Two rare TigerLight WA1111 mods -- I think about 500 lumen range. Both are throwers, not floods.
Light 1) A rare TigerLight with pepper spray body (no spray cannister provided) with custom battery of 6 high-current 1800mAh Kan cells. The cells are soldered together and wrapped. This light has been used a fair amount, but is in very good condition. Comes with high-temp window and Carley MOP reflector. I don't know whether this is a cone or stream pepper-spray tail cap. The box says it's a stream, but that may not be accurate. I tried it once and it didn't work very well with a stream cannister. May have been a bad cannister. You may want to call TigerLight to sort this out. I tried, but my email questions were not answered. $115.
Light 2) An extremely rare FBOP (no pepper spray) with a regulated battery pack of 8 Sanyo 2500mAh cells. This has Surefire's Hunt regulator which runs a WA1111 bulb in constant regulation. When the cells drop to the point where they are about to need recharging, the light will blink softly. The beam of this light is awesome, and it stays in regulation for 37 minutes. This is a MUCH better beam than the standard TigerLight. The downside is that I specified Sanyo 2500 cells in this mod. That was a mistake on my part because these Sanyos have the common problem of a high discharge rate. So while this light gives you 37 minutes of regulated lumens fresh off the charger (and you can run it right off the charger because it is regulated), the runtime drops to about 20 minutes if you use it 3 or 4 minutes for five or six nights in a row and don't charge in between uses. Comes with high-temp window and LOP Carley reflector. This is a used light, but nearly new and not heavily used. In excellent condition. Cells are soldered together and soldered to the switch, so there is virtually no resistance in the circuit. $115
Note: It's possible that I'm mixing up the LOP and MOP specifications. Those are difficult to me to distinguish between.
Extras (packed in orginal TigerLight boxes) I'll split these as evenly as I can if lights sell separately:
1 new Gen 4 TigerLight reflector/bulb in original package
2 spare shock-isolated UCL windows
2 spare LOP Carley metal reflectors
1 spare MOP Carley metal reflector with potted WA1111 bulb installed
9 spare potted WA1111 bulbs
1 stock Lexon shock-isolated bezel
1 stock Gen 1 or 2 reflector with bulb
2 chargers with AC transformers
1 12V cigarette adaptor for the charging cradle
The regulated FBOP light alone cost me more than three hundred dollars, but I will sell both lights as a package for $220 including Priority Mail shipping with confirmation US.
First "I'll take it" without conditions and with prompt PayPal payment gets it. PM me for my PP address. Foreign shipping will cost more.
