Ok... more stupid questions from a noobie...
Im putting together a light that will using a FM 6aa-2d holder, a downboy 917, and a LuxIII. This light wil be a secondary, lower output light source attached to another light.
1: im using a switch with multiple output levels, does it need to be wired between the db and the led, or the batt and the db?
2: does the DB put out a specific voltage? ive gathered the 917 refers to the mah it puts out... but ive found nothing on the voltage. Im trying to figure out what/where to order the emitter for this project... and since the leds are batched by voltage... im not sure what ive got, or what I need. ive been cautioned not to connect the batt untill the led is hooked up or id just do that, and break out the DMM.
Thanks!
Thanks!
