matrixshaman
I've got a couple FluPic lights currently as well as a POP2G so I'm familiar with at least some of the FluPics and how things work but the one I just put in my Jil DD has me lost. The FluPic said Rev.4 on it if that helps. It went in perfectly in the Jil DD and I can turn it on and get the following:
1 - fairly dim
2 - fairly dim but just a little brighter
3 - very bright
4 - fairly dim
5 - fairly dim - same as number 2
6 - very bright
7 - obvious that this is the set brightness mode - blinks then ramps up & down and when I tried changing this it affected step number 2 brightness
8 - same as 1
9? same as 2
10 same as 3 so I assume 8, 9, and 10 are just starting over at 1 thus
there seems to be 7 steps and NO change mode available as I never see the flashes associated with change mode. I also don't have any strobe, S.O.S. or beacon mode. Help!
1 - fairly dim
3 - very bright
4 - fairly dim
6 - very bright
8 - same as 1
9? same as 2
