ken2400 said:
So is that what the orig panel most likely is? A 1.5 volt one? What about putting it in parllel with the other panel?
I'm assuming you have a 1.5 volt battery in there. If so, you'll need a little over 1.5 to top it up. There are a lot of inexpensive solar yard lights around. The manufacturers usually are pressing very hard to keep down costs. This leaves you lots of room to come along afterwards and improve the units. For example you can buy two, remove the guts from one, add them to the second and get twice as bright a light (if you use both bulbs) or use just one bulb in the new unit and get twice the runtime.
There should only be a few parts in there. I would expect:
*A solar panel (collects the energy)
*A battery (stores the energy)
*A light, hopefully LED. (Uses the energy)
*An electric eye, so it knows when to turn on.
* A housing, to hold all the parts together and keep water out of the fiddly bits.
*There might be a circuit board in there too, I don't know.
You can step in at 'most any point and improve things if you choose to. Bigger battery, (same voltage though) parallel battery, bigger panel, parallel panel, possibly upgrade the LED. There is no particular reason all the parts have to be together in the same housing. The light needs to be where you need the illumination but the panel(s) can be up a tree where they always have light and never get stepped on, the battery(s) can be in a house or outbuilding or in the ground where they don't get frozen in cold weather.
