13.5 - 15 volt power source for television
Icebreak
by the river
The S.A. where I work recently came across a cool little 5' color TV that can also be used as a system monitor. They are looking for a power source that can step range from 13.5 to 15v. Or, power sources that are 13.5 and 15v respectively. I suggested Radio Shack which did not net a good result. Could one of you give me a direction to give my co-worker?
Brock
Green Bay, WI USA
Really any automotive, marine, RV or maybe even camping type store should have a 120vac to 12vdc converters. Just take a look at how much power the small TV wants to make sure the supply can handle it.
Icebreak
by the river
Thanks for your time on this Brock. Apparently this co-worker believes his little TV wants exactly 13.5v when used as a TV and exactly 15v when used as a monitor because it has two separate jacks. But I'll let him know your suggestion. I'm thinking that you are right; that 12v would power it just fine.He watched me post this at work and seemed pretty interested in CPF. He's a pretty respectful critter or I would not have shown him the site.
Evan
Maryland, USA
I've got a regulated 15 volt, 40 watt laptop supply I'll sell you for $5 or $10. In fact I have a few. Comes out to a fairly large diameter co-ax plug with about a 2.5mm center hole. Takes a standard PC power cord on the other side. 100-250 volts AC, 47-63Hz. About 3x5x1.5" send a PM if you're interrested.
Icebreak
by the river
Wow. Thanks Evan. I'll tell him Fri. Or, better yet, show him the response. I told him these folks were amazingly helpful.
