Ganp
This is a sign-up list for a long throw LED Head to fit Surefire E series hosts. As this is the first time I have done anything like this it has taken me some time to get organised. I think that I have it sorted now. I am sure someone will let me know if I am not doing this right ... there is bound to be something I have overlooked!!!
I will not be asking for payment until a head is ready to be shipped, so please indicate if you are just interested, or committed to buy and wish to go on the list. If there is enough commitment I will have some of the components CNC'd and make the rest myself. As I can only buy the optics in batches there need to be at least 18 orders to make a run viable. And as I would do this in my limited spare time, you will need to be patient too!!!
I am offering these as an assembled head plus a custom heatsink/can.
NB. No LED or driver - I wouldn't wish my soldering skills on anyone else .... if you can not assemble your own light engine, there are excellent modders out there who would do one for you.
The heads would be just like these ... maybe a bit darker!!
Specifications:-
Headshell - 6082 aluminium ... Hard Anodised - natural. Fine bead-blasted prior to anodising to give a silky smooth finish.
Lock ring - 6082 aluminium ... HA or raw finish - as preferred.
Collimator - Carclo 2-degree ... modified or standard - as preferred. Modified gives slightly tighter focus and helps throw.
Protective window - CR39 optical resin.
Heatsink/can - All alloy one-piece or separate heatsink/can - as preferred. Electrical connection is via the body-to-head thread. Ground is via a screw terminal in the top of the heatsink. Accepts 0.55" driver boards.
O-ring sealed - Not submersible but weatherproof - depending on the host.
Price £91.00 GBP + Postage
UK Recorded delivery £1.95
Royal Mail "International Signed For" airmail service to:-
Europe £7.89
Everywhere else £9.76
Photo gallery .... Hosts shown for illustration only!!!
In pictures 3 and 5 the light grey head on the 18500 body is only sandblasted - as a trial prior to anodising ... not how a run would be finished.
Beamshots .... same exposure used for each shot per set .... daylight white balance.
At 1 metre.
At 20 metres.
At 160 metres.
Please note:-
Usable with Lux lll's and Lux 5W. The above beamshots should give you the idea. Although these collimators can be made to focus the Cree XR-E any advantage is debatable and that mod' is NOT part of this project. Reasons can be seen here .
The collimator has a slight gold/yellow tint which may not be acceptable if you are particular about the tint of your LED .... looks good otherwise.
The HA colour will NOT match the Surefire finish....as I understand it, there is little control over colour matching when hard anodising, and I hope the look is acceptably unique.
Compatibility with other heatsinks is not known. As can be seen in the pictures, the LED is mounted on a short pedestal - necessary to avoid the solder tabs fouling the back of the collimator.
This head is just for throw .... the spill is untidy and useless, but this is not a problem in practice as the eye adjusts for the hotspot.
I doubt that this head would outperform a well souped-up M@G, but it IS a LOT smaller.
Still interested? Then please state your preferences (finish .. heatsink .. collimator) when you post. If you have previously shown interest in this thread .... please post here if you are still interested, and the time of your original posting will place you in this list. Any suggestions or constructive criticism will be welcome and considered, and changes incorporated if appropriate.
If there is enough interest for a small run then production can start in January.
Thank you for looking, and, interested or not ..... Merry Christmas.
Colin.
Specifications:-
Europe £7.89
At 1 metre.
At 20 metres.
At 160 metres.
Please note:-
Colin.
