Hellbore
First the excuses. I have had these Cree XR-E P2 or P3 (not sure which) stars sitting here for like a week now. The Elle flashlights I ordered from FifthUnit that I was gonna put them in haven't come yet and might not come for another 10 days. I have since ordered more Cree's in a brighter bin (P4). So I'm sitting on these Cree stars and nowhere to put them, but just ITCHING to see what they can do.
I start looking at my Nite-Ize mini-maglite and think hmm... I wouldn't care if you died... Shall I sacrifice you to satisfy my Cree curiosity? But that's silly, this flashlight uses three 5mm LED's... it can't work...
Next thing you know I have the Nite-ize module out and am tearing the LED's off the circuit board. The PCB appears to be superglued into a plastic housing. I manage to break it out of there, then my stomach sinks as I see that... when the circuit board broke out of the housing, a little inductor coil stayed behind SO I just tore the coil off the circuit board. Great. That's not all, looks like a SMD resistor tore off too, taking the solder pads with it Oh man I got sloppy didn't I... So I spend the next 30 minutes doing micro surgery to re-attach the little coil with its microscopic wires, then re-attach the SMD resistor with some copper wire to bridge areas where the traces were destroyed. Basically I had to rebuilt the circuit board becuase I tore it up pulling the module apart.
Finally I get it working again and take some measurements, it appears that the board is supplying 3.5 volts, and when I connect one of my Cree stars with my ammeter in series, I get 300 MA so I figure it should be acceptable. Then I do the most crappy mod ever and use wire snippers to cut the Cree star smaller so that it fits into the top of the plastic Nite-ize housing. So now I have a Nite-ize module with a Cree XR-E on it, and the pathetic Nite-ize reflector does almost nothing, so the end result is a completely floody beam that has pretty much no hotspot whatsoever. Wow good job probably the worst mod ever!
On the BRIGHT side, the Cree really surprises me at how bright it is! It's not even getting its normal 350 MA and it's shining way brighter than the Nite-Ize module did. In fact, when I tried using it in a dark room, the entire flood beam of the cree appears to be considerably brighter than the hotspot of the nite-ize original LED's! I am starting to understand why you guys are CREE-azy for Cree... these suckers perform...
I took the flashlight to bed with me and for a while I just lied there, turning the light on and off, marveling at how much it illuminated the whole room. The light that comes out of it is beautiful, such an elegant white light that I can't believe is coming out of my previously dim Nite-Ize module. The darn thing almost seems to be putting out as much light as my MagLED 3D except it's not focused so there's not a hotspot. I really am amazed at the LED technology compared to what it was in the past.
So anyway, it was my first attempt at a Cree mod so go easy on me...hehe... Besides, sometimes a flood beam is useful...
