Doug S
Assuming that you can hold the die temperature constant, as you increase current to a typical 5mm white LED the lm/mA drops beyond around 5-10mA. Has anyone done the experiments or seen published data that shows whether the output flux levels out to a constant value at some drive level or actually drops beyond some current level? The way to conduct this experiment would be to use a very low duty cycle pulsed drive to avoid bulk average temperature rise and short enough pulses that the die does not heat significantly during the ON time of any one pulse. At the other extreme, if the pulses are too short the data becomes tainted by effects of the charging current of the junction capacitance. The photo detector would need to either be very fast if you want to look at a single pulse or the overall photo detector system averages the combined pulse train in a linear fashion. I actually have everything necessary at hand to do this experiment but if it has already been done I see no merit in duplicating the effort. Anyone have any links to info on this question? TIA
