Today, I did something that I figured would happen sooner or later
. After finishing some simple soldering, I reached down and unplugged my iron.
Or at least I thought it was at the time
Quite some time later, I came back to my desk to clean up. I picked up the iron by the handle (as you should), then did a "heat test" by tapping it with my hand to make sure it was cool enough to put away. I've done this a 1000 times before without problems.
This time, I saw smoke rise from my hand!!
I had the iron plugged into a different spot than normal. I ended up unplugging my desk lamp, leavin the iron plenty hot
I managed to burn 4/5 fingers on my right hand - 2 with bad 2nd degree blisters (middle & thumb)
So, tip #1 - make sure your solderin iron is really unplugged!
feel free to add your own
-Darin
-Darin
