moon lander
i have a few questions. very sorry if these are obvious or stupid questions, i'm just missing some of the finer details about powering leds. i've done a lot of research to no avail and would really appreciate any advice on this:
white leds want 3.2-3.6 volts, but button cell keychain lights (like the photon clones) use no resistor and 2 batteries. so the leds are powered by 6 volts. isn't this likely to shorten the life of the led by a lot?
also, it seems that while testing my button cells voltage while powering an led, the voltage is around 2 volts, not 3. when not under load, the batteries test at about 3 volts. is this typical of all batteries? also, is this why the button cell lights dont kill leds quickly (4 actual volts powering the led)?
I'm misunderstanding something about voltage vs. current. with a circuit containing no resistor (photon clone), what will dictate the current? also, when an led rated at 3.7 volts is being under-powered by 2 volts, what dictates current then? i thought the resistor sets the current thru limiting, am i wrong?
do batteries have a maximum current output? if so does it differ with battery types? with no resistor will they output maximum current? the array wizard says i can use a 2 ohm resistor to feed 6 volts into a 3.7 volt led at 1000ma. that makes me think having no resistor at all would deliver even more current, so obviously i'm missing something here. also, are these calculations meant to be done with the batteries assumed (3v) voltage, or with the 2v the battery produces under load?
does anyone make a disc shaped resistor to insert between 2016 button cells in a photon clone? otherwise hard to fit one in there.
thank you in advance to anyone with advice!!
