The plan is to design a lamp assembly for the M3, M3t, and the M4.
We are going to use lamps that is similar in output as the Extreme High Output Lamps in the D26 and D36 series with a higher lead to coil length and most of all improved shocked resistence.
A different filament treatment coating technology will be used on these lamps that will improve the shock resistence and increase the output and colour temp by at least 5%, average life will also be longer.
The bulb will not "blacken" easily with this coating and chance of instaflash will be minimized because the filament will be much stronger.
So as you can see, it is easier said then done. The lamps with the above quality are only used by a few OEM clients who demands military spec lamps. One of them is RICO, the lamp after the treatment will perform like what you see on the videos on their site.
Pricing has not been discussed yet as the product is still in the testing stages.
That is all the update I can give you guys. I am keeping my mouth shut on this project until further notice.
Cheers,
