I upgraded my Fenix P1d CE with the Seoul P4 per Nerelus's instructions, all went well but I may have used too much crazy glue...The P4 is clouded over after a few days of use and the "dome" of the LED is hardenend.
I do see now a definite dimming due to the cloudiness. Will the cloudiness cause big time dimming as I am seeing?
Is this usually due to the crazy Glue fumes? I used crazy glue on the back of the reflector.
It's been a week and if I put a new P4 in do you think I will still have a clouding problem with the crazy glue even though it is very dry now? I did put paint over the crazy glue on the back of the reflector and it too is very dry now.
Also, can the clouding be caused by something else?
Thank you!
Thank you!
