Hi,
I ordered a SSC P4 from dealextreme http://www.dealextreme.com/details.dx/sku.2026
The emitter I got was not the same on the picture but that is not problem.
I manage to remove the lux led and replaced it with the seoul one.
The problem is that in the l0p se, at maximum is not bright at all, It is even less bright than with the luxeon led. I try adjusting the focus by turning the bezel but when the ssc is at the closest to the reflecter (no gap between the reflector and the led) All I got is a squared pattern on the wall.
Is this l0p driver not delivering enough to the seoul or should I shorten the lenght of the reflector or what?
What can I do to improve that plz?
I haven't learn yet how to post picture but if you need I can try and post some beamshot.
Thank you
Dardar
Thank you
Dardar
