VidPro
When a light comes off your head very close to your eyes, they say that you cannot see how high an item might be on the trail. a rock a hole whatever.
I have not really ever had a problem with that, and "depth perception" is of course not the correct wording.
ya gets your depth perception based on having 2 eyes seperated from eachother both showing different views combineed by elbraino. so you still have 2 eyes, and they still see 2 pictures.
What you don't have indeed, is the SHADOWS.
so out there on a dark trail with my light set very low, i thought about this, and its true, you dont see trail shadows, so indeed a larger rock doesnt look that much higher than a smaller rock, it is hard to tell how far an item sticks UP out of the trail.
so i put my headlight UP as far as i could, and still nothing, then i lowered it down, and sure enough shadows dependant on height were quite obvious.
and then i thought, WHY? why is there not a Belt Buckle light? using a flat li-poly type of cell a led , and short optics , a belt buckle light would be pretty easy to make.
I was holding my headlamp there at belt buckle level, and ran into a tree :laughing: and had this thought.
a headlight used for a LONG time, often needs a Belt battery pack already, ya already need a belt, and its a good place to run wires through, a buckle would be a good item to be a heat sink (vrses this plastic junk were getting).
just seems really possible.?
