Hello all!
I found that my rotary tailcap no longer stays locked and spins. I did remove the whole tailcap assembly about a month ago to replace the batteries. The light worked a couple days ago and I went to use it today and I went to turn it on and found that it was unlocked and would not light. So, I proceed to check the switch and it turns all the way around!!
I took it apart and reassembled it and the plastic switch turns all the way around. Can I get a tailcap replacement w/o sending it back to the company? I did a Google search for parts, but found none. Any help is appreciated.
Thanks
Thanks
