In short the plan was to use 7.2V batteries( NiMH initially ) to power 2 Seoul P4's through a shark driver. all the bits are ordered now, so little going back. :thumbsup:
i had originally provisioned that 2 leds would be about 8V and that 7.2V and falling under use from the battery would be a suitable source.
but i've since gone back over the finer details to see that the Seoul's are 3.25 volts ... as i understand it, this would mean the supply is greater than Vfout and the LEDs would blow. :sigh:
But i dont want to swap to a buckpuck driver as i would still be needing to cover the 2V overhead ontop of the 6.5V of the LEDs, which i dont have from a 7.2V battery
It has to be pairs due to the enclosure.
So, am I right in saying that the 7.2V supply would blow the circuit? :thumbsdow
If so, would it be possible to pre-regulate the 7.2V down to 5V and then run the shark off the regulated voltage? :thinking:
Am I right in saying that if the LED string is run at a max of 1000mA, then the supply current is going to be slightly higher? If so, by how much?
I could fit in a 5V regulator with a 5A capacity between the battery and the shark. Would that be enough to handle the shark?
I would really like to persevere with the 7.2V NiMH route as it would make for an easy swap further down the line to LiPo batteries too.
many thanks in advance.
Donald
Donald
