I recently acquired a p2d from a certain Christmas giveaway on some great forum, well anyway it does not work properly at all. Sometimes with a fresh battery, it will only work in a mode thats lower then low even if I twist the head all the way. If i try to change modes it blinks and stays in the same really really low mode (guess would be 2-3 lumens). If I let it rest for a few minutes it will usally start to work again. But recently it started to completely fail. I turned it on and nothing happen, I checked that battery and it measured 3.14 volts, I even tried a fresh surefire cell and still nothing (it is def not the switch since it works perfectly on my p3d). I have dropped it before but only once and no more then 2 feet onto grass. Should I try to contact the Fenix store even tho I did not purchase it from there?? Someone please help :sigh::sigh:
Thanks
Thanks
