ConfederateScott
I swap my old KL1 back and forth from a one cell body to a two cell body just depending on what I need at the moment. Can the KX1 head be interchanged like the KL1 head or will I fry something if I do?
Any voltage significantly above the vf of the led, about 3.2- 3.5 volts, will cause the circuit to not regulate and the LED will be directly driven by the battery(s).
Have you seen this in action? I don't have a KX1, but the reports I've read say it's even worse than what you describe. The circuit appears to go into some kind of overvoltage protection mode, and the light flashes on and off rapidly.
