Dropped my 2d m@g with installed TLE-300:sigh:
It still functions but the glued on optics came off.
Can anyone recommend a good temperature resistant non-conductive glue so I can reattach the optics.\
Thank you in advance.
AFAIK, any thermal glue from Ace Hardware or similar hardware stores will work, and since it's an LED, it doesn't have to deal with the massive heat of an incan. If you want to go right the first time (and I'm not saying the thermal hardware glue won't be right), you could use the stuff at http://www.arcticsilver.com/arctic_alumina_thermal_adhesive.htm
I've used it in the past in some mag mods and it works great, especially with Incans. The heat from LED's should be no challenge.
