Get DX SSC! The tint on mine is superb! I would say WO tint, I got the EMS upgrade and my light was at my door in 4 days!
I did a mini review on DX site about the SSC.
http://www.dealextreme.com/details.dx/sku.2392
Quote
Pros: The tint is superb!!!! I would say it's a WO tint, SNOW white! and brighter than the Fenix P1D with Q5 cree on turbo! I would estimate between 120-150 lumens.
The reflector is light orange peel, has good sidespill and throw, with no artifacts, useful for distances up to 40-50 meters (120 - 150ft)Led is perfectly centered!
The tail button is very soft and reliable, overall the build quality is excellent.
The finish IS HA III it does not scratch off with the edge or tip of a knife, color is very uniform, no mismatch color can be found.
It has 32 levels that can be adjusted in under 3 seconds from brightest to dimmest
I like the lanyard! but get rid of that shiny metal crimp or make it black.
The brightness controls are easy to use and feel nice.
Cons: - Does not tailstand
- The head is sealed with glue, is not easy to open it up to replace / upgrade the led, but the tint and brightness is excelent.
- There are very few small dust particles behind the lens and reflector, doesn't affect performance.
- It is actually 32 levels of light, the higher ones are not very different from each other (level 32-20),and there is a noticeable increase in brightness between the lowest and the next(level 1-2).
- The tailbutton is easy activated should be recessed a bit more to be able to tailstand.
-There was no lube on the tailcap orings.
Other Thoughts: My suggestion would be to tweak the levels to get something like beacon(at3%), 3,5,7,10,20,30,40,50,60,70,80,100% of light brightness.
Make it 1 CM shorter (1/2 inch) drill 2 holes for the lanyard to be able to tailsand.
Get rid of the glue around the bezel to make it user moddable.
Install glow in the dark Oring around the reflector to be able to locate at night.
Bottomline: Buy it! Can't go wrong with this one!, you will love the tint!
HTH
AlexGT
End Quote
