Well as some of you might know, i busted my KL1 after having it for about 2 mins. I unscrewed the the bezel in half and severed the wires from the board to the LS. Anyway I was trying to solder it back and the only leads i could find with voltage on the board are putting out about 5.5 volts. Well i soldered the wires back there and the KL1 seems REALLY bright...??? I havent seen the KL1 at night since i busted it before i could try, but is that how many volts the LS should be run at?? The light seems to get fairly hot after about 1 min or so of continuous usage. Im kinda concfused since i think that if i was feeding it too much power it would be fried already. Any comments?? Maybe this is how the KL1 is originally?
