Khaytsus
I've got a Tec 20 in the mail, but I was at a sporting goods store and they had Tec 40's for $12 so I had to get one, at much dismay from the wife.
To reiterate another thread, BE VERY vigilant about putting the batteries in the right way. It is marked correctly, but keep in in mind.. The - side you see the negative end of the battery, the + you see the positive side with the button, or you will smoke your light.
I checked three times, double checked, triple checked ;-) Took the bulb out, saw which contact was the middle, double-checked again to make sure that it was right /ubbthreads/images/graemlins/smile.gif
That said, to the post.. I notice the EverLED sits up really far in the reflector, and due to the spring design in this light it seems it would be easy to put some sort of spacer between the EverLED and the reflector to stop it from going so far up inside the reflector. Depending upon how thick, the spring may or may not need adjusting.
Now granted the beam from the Tec 40 (and I assume Tec 20 will be the same) looks great, but it seems like there is too much side spill which I think will be reduced (thus more light in the spot) if the led is not quite as far into the reflector as it is now.
Anyone tried this or thought about it? I might look around for something tonight to tinker with it to see if it's feasable or silly..
Solid little light.. I love it. Gonna have a black Tec 40 and Tec 20, probably have the EverLED in the Tec 20 most times and a Dorcy LED in the Tec 40, but who knows.. I swap bulbs around /ubbthreads/images/graemlins/smile.gif
