Those are not rechargeables at all. They are just the plain cheap AA alkaline batteries. As an earlier thread pointed out, if you don't completely drain the batteries and top up the charge as soon as possible, those non-rechargeable alkalines can accept a few recharge cycles.
The primary purpose of the battery pack is that if you get a totally flat car battery---like one night you forgot to turn off the headlight---then you can save yourself by plugging the battery pack into the cigerret lighter socket and let the alkalines charge up the car battery to a point you can start the engine. This can be useful if you are in a camping trip to some remote areas where AAA/CAA help is just out of the question.
For this kind of emmergency use, you probably won't need the battery for more than twice a year. Even if the battery pack can not be charged at all, it probably still worth keeping one of these in your car when going for a field trip just as a back-up. I will not attempt to use it to power the other crazy stuffs as printed on the battery pack, because I don't want to spend some $40 on half hour of "entertainment".
And yes, it will go BANG or leak if it is not used/charged carefully or you are just unlucky.
