Geminidan
Sold The head is a Milkyspit Project-M eXtreme X813-M3. It delivers at least 813 lumens overall output. The head was ruggedized for law enforcement use. It'll run on any power source up to 9 volts... the buyer should NOT run with more than 9 volts. It will work on 2x18650 rechargeables, or 2x18500, or 2x A123Systems, or 2x Emoli. It will also work on 3x123 primaries. It will also work on an M6 body with 6x123 primaries in the SureFire caddy. (The caddy is wired to be 9 volts even though there are 6 cells.) Other setups might work, too, as long as the incoming voltage is 9 volts or less.
The emitters in that head are CreeXRE R2WC for an intense, "instableach" white. Custom RPM Clickie with no-trits!!
The body has 28x Viton #16 o-rings on it for grip... Viton is a higher-grade o-ring material that should wear better and last longer, without drying out as easily as normal o-rings would.
Real White Light Super Thrower with overspill
Grab it now with no waiting time, perfect no marks or scratches
:mecry:
Asking $ 515.00 PayPal cash Delivered
:mecry:
