Gene
Years ago I bought two of the old discontinued "Maximizer", (a one AA cell MM body extension and special bulb), kits for the mini Mag. They didn't make much difference in brightness but the one AA cell body extension is very well made and matches up with the MM body perfectly. They eventually were put away because the Maximizer replacement bulbs were wildly expensive.
When Oplalec came out with the NewBeam, I found one of the Maximizer body extensions and tried the NewBeam making a 3 cell mini Mag. It worked great! I decided to try it with TWO of the Maximizer extensions to make a 4 cell MM but I couldn't find the other Maximizer and figured it had been lost through the years.
I stumbled on the "lost" Maximizer awhile ago and finally made a 4 AA cell MM! It works even better than the 3 cell MM with the NewBeam! It's at least 25% brighter with the 4 AA cells. It's probably being overdriven a bit with the 4 cells but so far so good and it keeps working fine.
It's a bit unusual looking as it's 11 1/4" long! As I said though the Maximizer extensions mate with the MM body perfectly so it's one unique and neat looking mini Mag! With 4 AA cells, the batteries should last almost forever with the NewBeam. It also has a nice comfortable feel and it can double as an emergency baton if needed! /ubbthreads/images/graemlins/smile.gif
