MrNaz
I am trying to work out the cheapest way to run clusters of 3 XPE LEDs from 12v. Given that I need many such assemblies, the cost of using a board rules it out, preferably I would like to simply use an inline resistor given that the 12v is already coming from a regulated output.
Normally to work out the resistor to use to get a given voltage over a load I would assume that voltage is dissipated evenly throughout the circuit, but in this case, I don't know what the resistance is. In any case, I think that's the wrong way to be going about it.
I want the 12v stepped down to 11.1v (3 * 3.7v) for the LED load. In order to calculate the resistor needed, do I have to get a multimeter out and measure the resistance of each cluster? Or am I doing it wrong?
