thank you all very much for your feedback. i didn't mean to complain at all, i like the light as it is, i just meant to post some first impressions.
DHart said:
The Quarks excel at being throwers. ANd they're great general use lights as well. But they can't be everything for all needs.
The kind of light you are describing with a wider, softer edge hotspot and brighter spill makes for a wonderful general use light, especially indoors, and there are a few awesome lights which will give you that: LF3XT, LF2XT, D10, etc.
No single light can perfectly meet every illumination need!
i don't have many other good led-lights that i could compare the quark with so i was not sure what e.g. 'plenty of spill' or 'little flood' actually would look like.
spill is fine and sure the quark makes a great thrower!
funny you mention the LF3XT, i was waiting for the looong announced 2aa tube fot this one quite some time but finally decided that i could use the light pretty soon for my travels to remote parts of south-east-asia instead of waiting and hearing excuses for further delays.
i absolutely don't regret having decided on a quark now but i might think about getting a diffuser lens if available one day.
Palor said:
Yep! I bought the Olight T-series Red Filter and it fits perfectly to the Quark 2AA.
Fenix filter will not function (they have a smaller diameter).
thank you very much for this information! maybe if you once find the time, could you take a closeup picture showing the installed filter from the side or diagonal?
how tight does the filter sit? i'd be a bit afraid of losing it maybe...
regarding the beacon, i like the flash rate but was surprised it flashes at full power. for 99% of my uses a lower mode (maybe 3 or 4) would be enough, the only situation for full-power beacon i could imagine would be an emergency case but there i might switch to s.o.s. mode probably.
talkin about the s.o.s. signal mode, anybody knows what runtime can be expected here? it's not listed in the manual. i also not sure if s.o.s. uses full power or maybe the 70 lumen setting...
EDIT: beacon also ramping up and down here - nice!
