I have a Jet 1 Pro module that I would like to put a XPG into. I need some help getting it opened. Do you need to push everything out the back from the front or what? TIA
C
Thanks Norm that was what it took although it was so tight that I felt the need to relieve a little tension so I cut it.It could be done without cutting though with the right extraction tool.
Here are some pics.
The beam looks a little brighter than the r2 with much more spill and a larger hotspot.
It needs to be driven harder
