ARC mania
I designed helped design these heads for a small sale here in Japan. I have 2pcs left over. One is HAIII OD and other is HAIII black. These are SF compatible heads made for the E1e or E2e. Has three levels of brightness with memory and reverse polarity protection. Would like to ask $262.00 shipped for one or take both for $500.00. Will need a few days to ship. Here are the specs:
LED: SST-50-WJ Star
Brightness levels: 3, 5%, 30%, 100%
Drive current at 100% = 1.5 amps using an RCR123 rated at 3.7 volts.
Can use CR123 or RCR123 (min. 2.4 volts, max 4.2 volts)
Reverse polarity protected
Anodizing: HA III black/OD
Chem-kote inner module
Mineral glass lens
ARC mania
LED: SST-50-WJ Star
Mineral glass lens
ARC mania
