recDNA
- Joined
- Jun 2, 2009
- Messages
- 8,761
I'm looking for a floody X-PE neutral white flashlight. I was going to go for the Romisen RC-N3 II neutral white 2 mode but I read it was better for throw than flood. Does the Romisen have an OP reflector? If not I wonder if I could put one in to make it floodier.
I want a floody light (or at least good spill) because this light is going in the bathroom where it may be used to examine skin but has enough power to second as an indoor flashlight to light up a room if there is a power failure. A little tiny hotspot is no good for looking at a mole, cut, splinter etc. I don't want to bother with a diffuser. IME diffusers cut down too much on output. Even my Eagletac T20C2 looks dim with a diffuser on it. Good spill will do the trick.
I'm looking for 130+ OTF lumens on high and a low or medium between 20 - 80 lumens. I don't care about low below 20 lumens but if it is a 3 mode light a low-low is OK.
If you have read my posts in the past you may be surprised I am looking for neutral white. I prefer stark to bluish white normally but that's no good for a skin exam. Incandescent would do the job but I hate the rings. I'd like a nice smooth beam. Preferably no strobe or hidden strobe.
The sold out Quark tactical 123 in neutral white would have been perfect but it is a little more than I'd like to spend anyway. I'd like to keep it under $40 if I can. Is 4sevens going to make a neutral white mini?
I was tempted by the neutral white Cree MC-E but I'm afraid the low will be too bright and it is a little big for the bathroom. It's going to go in a little plastic bin with my razor etc.
I don't want to spend a fortune if I can avoid it. If there is nothing better in my price range I'll go for the Romisen.
