Flaky LSH-P
Status
Not open for further replies.
LitFuse
Sunshine State
My LSH-P just started acting up this evening. With the head screwed on tight, the light doesn't work. If I unscrew it a bit, it works fine. I swapped the Kroll and have the same problem. Anyone know what's going on here? Thanks.
Peter
dtsoll
nebraska
Peter,
I'm not sure but it sounds like it could have the flex problem talked about here some time back. I'm sure someone more knowledgeable than I will chime in with the real problem though /ubbthreads/images/graemlins/grin.gif Mr. Gransee will surely fix you up though. doug /ubbthreads/images/graemlins/smile.gif
**Two adjoining sentences should not both end in though**
Gransee
Mesa, AZ. USA
Yes, I doubt it is the flex. We haven't seen a case of that since the rev2 design was implimented. You can send it in and let us take a look at it.
Peter
chamenos
Singapore
could it be that the retaining ring wasn't screwed down all the way when it was assembled?
Gransee
Mesa, AZ. USA
It is entirely possible. It's hard to speculate at this point without seeing the actual unit.
Peter
dtsoll
nebraska
Dang it, I wanted to be right just once. Maybe next time. /ubbthreads/images/graemlins/grin.gif
Doug /ubbthreads/images/graemlins/smile.gif
Status
